ArcGIS.Core.Data.Knowledge.Analytics Namespace / PathsEntitiesAndRelationships Class / RelationshipsUIDs Property
Example
    Gets the UIDs of relationships used in paths.
    Syntax
    Public ReadOnly Property RelationshipsUIDs As Object()
    public object[] RelationshipsUIDs {get;}
    Example
    List out FFP Results Relationships
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(async () =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "List out FFP Results Relationships";
        //set up config
        var results = kg.RunFilteredFindPaths(ffp_config);
        if (results.CountPaths == 0)
          System.Diagnostics.Debug.WriteLine("FFP returned no paths");
          return;
        //print out paths by increasing length, min cost, max cost
        var path_by_len_indices = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingPathLength
                                    .Select(idx => idx.index);
        var path_by_min_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMinPathCost
        var path_by_max_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMaxPathCost
        var x = 0;
        StringBuilder sb = new StringBuilder();
        foreach (var path_indeces in new List<IEnumerable<long>> {
        path_by_len_indices,
        path_by_min_cost,
        path_by_max_cost})
          if (x == 0)
            sb.AppendLine($"Relationships by length: {path_by_len_indices.Count()}");
          else if (x == 1)
            sb.AppendLine($"Relationships by min cost: {path_by_min_cost.Count()}");
          else if (x == 2)
            sb.AppendLine($"Relationships by max cost: {path_by_max_cost.Count()}");
          x++;
          foreach (var path_idx in path_indeces)
            var path = (ResultPath)results.MaterializePath(path_idx);
            sb.AppendLine(
              $"Path[{path_idx}] length: {path.Length}, min: {path.MinCost} max: {path.MaxCost}");
            var sorted_set = new SortedSet<ulong>();
            sorted_set.Add((ulong)path_idx);
            var per = results.ExtractPathsEntitiesAndRelationships(sorted_set);
            var idx = 0;
            foreach (var rel_uid in per.RelationshipsUIDs)
              sb.Append($" RelationshipsUIDs[{idx}]: ");
              var uid = FormatID(rel_uid.ToString());
              var rel_info =
                $"{per.RelationshipTypeNames[per.RelationshipTypes[idx]]}:{uid}";
              sb.Append($"{rel_info}\r\n");
              //From entity:
              var entity_idx = per.RelationshipsFrom[idx];
              var origin_uid = FormatID(per.EntitiesUIDs[entity_idx].ToString());
              var origin = $"{per.EntityTypeNames[per.EntityTypes[entity_idx]]}:{origin_uid}";
              sb.Append($"   RelationshipsFrom: {origin}\r\n");
              //To entity
              entity_idx = per.RelationshipsTo[idx];
              var dest_uid = FormatID(per.EntitiesUIDs[entity_idx].ToString());
              var dest = $"{per.EntityTypeNames[per.EntityTypes[entity_idx]]}:{dest_uid}";
              sb.Append($"   RelationshipsTo: {dest}\r\n");
              idx++;
            var rel_str = sb.ToString();
            System.Diagnostics.Debug.WriteLine(rel_str);
            sb.Clear();
    string FormatID(string id)
      id = id.ToUpperInvariant();
      if (!id.StartsWith('{'))
        id = '{' + id;
      if (!id.EndsWith('}'))
        id += '}';
      return id;
    Requirements
    ArcGIS Pro version: 3.6 or higher.
