ArcGIS.Desktop.Mapping Namespace / LasPointClusterSelectionFilter Class / SearchRadius Property
Example
    SearchRadius Property (LasPointClusterSelectionFilter)
    Gets and sets the search radius in meters. The default value is 0.2 meters.
    Syntax
    Public Property SearchRadius As Double
    public double SearchRadius {get; set;}
    Remarks
    This is the maximum distance that points can be between one another before the selection stops.
    Example
    Select using LasPointClusterSelectionFilter
      // must be on MCT
      var clusterFilter = new LasPointClusterSelectionFilter();
      clusterFilter.VisiblePoints = true;
      clusterFilter.ClassCodes = new List<int>();  // empty list means all classification codes
      clusterFilter.FilterGeometry = polygon;
      clusterFilter.SearchRadius = 0.5; // meters
      clusterFilter.MaximumNumberOfPoints = 500;
      var clusterSelCount = await lasDatasetLayer.SelectAsync(clusterFilter, SelectionCombinationMethod.New);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
