ArcGIS.Desktop.Mapping Namespace / LasPointRailSelectionFilter Class / MaximumLength Property
Example
    Gets and sets the maximum length in meters. This is the longest allowable distance in both directions along the rail for selection points as rail points. The default value is 200 meters.
    Syntax
    Public Property MaximumLength As Double
    public double MaximumLength {get; set;}
    Example
    Select using LasPointRailSelectionFilter
      // must be on MCT
      var railFilter = new LasPointRailSelectionFilter();
      railFilter.VisiblePoints = true;
      railFilter.ClassCodes = new List<int>();  // empty list means all classification codes
      railFilter.FilterGeometry = polygon;
      // configure a few of the properties and accept defaults for others
      railFilter.SearchRadius = 0.5; // meters
      railFilter.RailThickness = 0.2; // meters
      railFilter.MaximumLength = 225; // meters
      var railSelCount = await lasDatasetLayer.SelectAsync(railFilter, SelectionCombinationMethod.New);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
