ArcGIS.Desktop.Mapping Namespace / LasPointRailSelectionFilter Class / RailThickness Property
Example
    Gets and sets the rail thickness in meters. This limits the search distance to the left and right along the rail. The default value is 0.1 meters.
    Syntax
    Public Property RailThickness As Double
    public double RailThickness {get; set;}
    Example
    Select using LasPointRailSelectionFilter
      // must be on MCT
      var railFilter = new LasPointRailSelectionFilter();
      railFilter.VisiblePoints = true;
      railFilter.ClassCodes = new List<int>();  // empty list means all classification codes
      railFilter.FilterGeometry = polygon;
      // configure a few of the properties and accept defaults for others
      railFilter.SearchRadius = 0.5; // meters
      railFilter.RailThickness = 0.2; // meters
      railFilter.MaximumLength = 225; // meters
      var railSelCount = await lasDatasetLayer.SelectAsync(railFilter, SelectionCombinationMethod.New);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
