ArcGIS.Desktop.Mapping Namespace / LasPointRailSelectionFilter Class / SearchRadius Property
Example
    SearchRadius Property (LasPointRailSelectionFilter)
    Gets and sets the search radius in meters. This is the distance from the moving window's endpoints within which a point is assessed as a rail point. The default value is 0.25 meters.
    Syntax
    Public Property SearchRadius As Double
    public double SearchRadius {get; set;}
    Remarks
    A good value for the search radius should allow for jumping gaps but not be excessively large, as a larger value will significantly slow down the selection.
    Example
    Select using LasPointRailSelectionFilter
      // must be on MCT
      var railFilter = new LasPointRailSelectionFilter();
      railFilter.VisiblePoints = true;
      railFilter.ClassCodes = new List<int>();  // empty list means all classification codes
      railFilter.FilterGeometry = polygon;
      // configure a few of the properties and accept defaults for others
      railFilter.SearchRadius = 0.5; // meters
      railFilter.RailThickness = 0.2; // meters
      railFilter.MaximumLength = 225; // meters
      var railSelCount = await lasDatasetLayer.SelectAsync(railFilter, SelectionCombinationMethod.New);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
