ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / Subcircuit Class / Item Property / Item(Int32) Property
The index of the user field.
    Gets and sets the value of a user field with the given index. This property must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Property Item( _
       ByVal index As Integer _
    ) As Object
    public object Item(
       int index
    ) {get; set;}
    Parameters
    index
    Property Value
    The value of the user field.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
