ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / Subcircuit Class / Item Property / Item(String) Property
The field name or field alias.
    Gets and sets the value of a user field with the given name or alias. This property must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Property Item( _
       ByVal fieldName As String _
    ) As Object
    public object Item(
       string fieldName
    ) {get; set;}
    Parameters
    fieldName
    Property Value
    The value of the user field.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
