ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / UnitIdentifierManager Class / ReserveUnitIDs Method
Represents an equipment container (UnitIdentifier), such as a rack or a switch.
Represents the first unit in the gap range to reserve.
Represents the last unit in the gap range to reserve.
Example
    Reserves a range to create a gap in the unit range UnitRange space of an equipment container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub ReserveUnitIDs( _
       ByVal container As UnitIdentifier, _
       ByVal firstUnit As Short, _
       ByVal lastUnit As Short _
    public void ReserveUnitIDs(
       UnitIdentifier container,
       short firstUnit,
       short lastUnit
    Parameters
    container
    firstUnit
    lastUnit
    Exceptions
    ExceptionDescription
    This operation cannot be invoked inside ArcGIS.Core.Data.Geodatabase.ApplyEdits or when an edit operation is in progress.
    A geodatabase-related exception has occurred.
    Example
    Reserve a gap in an equipment container in the utility network
    await QueuedTask.Run(() =>
      using (UnitIdentifierManager unitIdentifierManager = utilityNetwork.GetUnitIdentifierManager())
        var networkSource = utilityNetwork.GetDefinition().GetNetworkSource("TelecomDevice");
        UnitIdentifier containerUnitIdentifier = new UnitIdentifier(networkSource, globalID);
        // Reserve a gap in the container for units 2 through 5.
        unitIdentifierManager.ReserveUnitIDs(containerUnitIdentifier, 2, 5);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
