ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / WavelengthScheme Class
Members Example
    Represents the wavelength scheme in the telecom domain.
    Syntax
    Public NotInheritable Class WavelengthScheme
    public sealed class WavelengthScheme
    Example
    Get the telecom domain network and network information from the utility network
    await QueuedTask.Run(() =>
      if (!utilityNetwork.HasTelecomNetwork)
        Console.WriteLine("The utility network does not have a telecom domain network.");
      // Get the telecom domain network from the utility network definition.
      IReadOnlyList<DomainNetwork> domainNetworks = utilityNetwork.GetDefinition().GetDomainNetworks();
      foreach (DomainNetwork domainNetwork in domainNetworks)
        if (domainNetwork is TelecomDomainNetwork tdn)
          // The telecom domain network was found.
          telecomDomainNetwork = tdn;
          // Get information about circuit properties from the telecom domain network.
          CircuitProperties circuitProperties = telecomDomainNetwork.CircuitProperties;
          Console.WriteLine($"Maximum hops in a circuit: {circuitProperties.MaxHops}");
          Console.WriteLine($"Number of paths in a circuit: {circuitProperties.NumPaths}");
          // Get the circuit color scheme information
          IReadOnlyList<ColorScheme> colorSchemes = telecomDomainNetwork.ColorSchemes;
          foreach (ColorScheme colorScheme in colorSchemes)
            string colorSchemeName = colorScheme.Name;
            int colorSchemeID = colorScheme.ID;
            IReadOnlyList<ColorSchemeGroup> colorSchemeGroups = colorScheme.Groups;
            foreach (ColorSchemeGroup group in colorSchemeGroups)
              Console.WriteLine($"Color Scheme: {colorSchemeName}, Group: {group.Name}");
              // Color codes
              IReadOnlyList<ColorCode> colorCodes = group.ColorCodes;
              foreach (ColorCode colorCode in colorCodes)
                Console.WriteLine($"Color Code: {colorCode}");
              // Capacities
              IReadOnlyList<int> capacities = group.Capacity;
              foreach (int capacity in capacities)
                Console.WriteLine($"Capacity: {capacity}");
          // Use the telecom domain network to get additional information about the network.
          IReadOnlyList<WavelengthScheme> wavelengthSchemes = telecomDomainNetwork.WavelengthSchemes;
          IReadOnlyList<DividePolicy> dividePolicies = telecomDomainNetwork.DividePolicies;
          IReadOnlyList<CombinePolicy> combinePolicies = telecomDomainNetwork.CombinePolicies;
          IReadOnlyList<string> diagramTemplateNames = telecomDomainNetwork.DiagramTemplateNames;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.UtilityNetwork.Telecom.WavelengthScheme
    Requirements
    ArcGIS Pro version: 3.7 or higher.
