ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / CircuitTracer Class
Members Example
    CircuitTracer Class
    The CircuitTracer class performs a circuit trace.
    Object Model
    CircuitTracer ClassUtilityNetwork Class
    Syntax
    Public NotInheritable Class CircuitTracer
       Inherits Tracer
    public sealed class CircuitTracer : Tracer
    Example
    Run a circuit trace in the telecom domain network
    await QueuedTask.Run(() =>
      using (TraceManager traceManager = utilityNetwork.GetTraceManager())
      using (CircuitManager circuitManager = utilityNetwork.GetCircuitManager(telecomDomainNetwork))
        Circuit circuitToTrace = circuitManager.GetCircuits(new CircuitFilter(circuitNames)).FirstOrDefault();
        TraceConfiguration traceConfiguration = new TraceConfiguration()
          MaxHops = 10,
          NumPaths = 5,
          DomainNetwork = telecomDomainNetwork,
          InferConnectivity = true
        TraceArgument traceArgument = new TraceArgument(circuitToTrace)
          Configuration = traceConfiguration,
          ResultTypes = new List<ResultType> { ResultType.Circuit },
          ResultOptions = new ResultOptions() { IncludeGeometry = true }
        CircuitTracer circuitTracer = traceManager.GetTracer<CircuitTracer>();
        IReadOnlyList<Result> results = circuitTracer.Trace(traceArgument);
        // Iterate through the circuit trace results
        foreach (Result result in results)
          if (result is CircuitResult circuitResult)
            IReadOnlyList<CircuitPath> circuitPaths = circuitResult.CircuitPaths;
            foreach (CircuitPath circuitPath in circuitPaths)
              Circuit circuit = circuitPath.Circuit;
              TracePath path = circuitPath.Path;
              IReadOnlyList<PathConnectivity> pathConnectivities = path.PathConnectivities;
              foreach (PathConnectivity pathConnectivity in pathConnectivities)
                Console.WriteLine($"Edge: {pathConnectivity.Edge.GlobalID}, Junction: {pathConnectivity.Junction.GlobalID}");
              Geometry geometry = circuitPath.Geometry;
              IReadOnlyDictionary<int, TracePath> sectionPaths = circuitPath.SectionPaths;
              foreach (KeyValuePair<int, TracePath> sectionPath in sectionPaths)
                int sectionID = sectionPath.Key;
                TracePath sectionGeometry = sectionPath.Value;
                Console.WriteLine($"Section ID: {sectionID}, Section Geometry: {sectionGeometry.Geometry.ToJson()}");
          else
            Console.WriteLine("Unexpected result type.");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.UtilityNetwork.Trace.Tracer
          ArcGIS.Core.Data.UtilityNetwork.Trace.CircuitTracer
    Requirements
    ArcGIS Pro version: 3.7 or higher.
