ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / PathConnectivity Class
Members Example
    Object Model
    PathConnectivity ClassElement ClassElement Class
    Syntax
    Public Class PathConnectivity
    public class PathConnectivity
    Example
    Run a path trace in the telecom domain network
    await QueuedTask.Run(() =>
      using (TraceManager traceManager = utilityNetwork.GetTraceManager())
      using (NetworkSource deviceNetworkSource = telecomDomainNetwork.NetworkSources.First(f => f.Name.Contains("TelecomDevice")))
      using (AssetGroup assetGroup = deviceNetworkSource.GetAssetGroup("Port"))
      using (AssetType assetType = assetGroup.GetAssetType("Port"))
        Guid startGuid = new Guid("4BB4560A-34F3-4BBA-93D5-C5D6B26F2709");
        Guid stopGuid = new Guid("32203C76-E484-473A-AEA5-B1AB92A0C198");
        TelecomElement startElement = utilityNetwork.CreateElement(assetType, startGuid) as TelecomElement;
        TelecomElement stopElement = utilityNetwork.CreateElement(assetType, stopGuid) as TelecomElement;
        List<TelecomElement> startingLocations = new List<TelecomElement>() { startElement };
        List<TelecomElement> stoppingLocations = new List<TelecomElement>() { stopElement };
        TraceConfiguration traceConfiguration = new TraceConfiguration()
          MaxHops = 100,
          NumPaths = 2,
          DomainNetwork = telecomDomainNetwork,
          ValidateConsistency = true
        TraceArgument traceArgument = new TraceArgument(startingLocations)
          StoppingLocations = stoppingLocations,
          Configuration = traceConfiguration,
          ResultTypes = new List<ResultType>() { ResultType.Path },
          ResultOptions = new ResultOptions { IncludeGeometry = true }
        PathTracer pathTracer = traceManager.GetTracer<PathTracer>();
        IReadOnlyList<Result> results = pathTracer.Trace(traceArgument, ServiceSynchronizationType.Asynchronous);
        // Iterate through the path trace results
        foreach (Result result in results)
          if (result is PathResult pathResult)
            IReadOnlyList<TracePath> paths = pathResult.Paths;
            foreach (TracePath path in paths)
              Element startLocation = path.StartLocation;
              Element stopLocation = path.StopLocation;
              Geometry pathGeometry = path.Geometry;
              IReadOnlyList<PathConnectivity> pathConnectivities = path.PathConnectivities;
              foreach (PathConnectivity pathConnectivity in pathConnectivities)
                Console.WriteLine($"Edge: {pathConnectivity.Edge.GlobalID}, Junction: {pathConnectivity.Junction.GlobalID}");
          else
            Console.WriteLine("Unexpected result type.");
    Run a circuit trace in the telecom domain network
      using (CircuitManager circuitManager = utilityNetwork.GetCircuitManager(telecomDomainNetwork))
        Circuit circuitToTrace = circuitManager.GetCircuits(new CircuitFilter(circuitNames)).FirstOrDefault();
          MaxHops = 10,
          NumPaths = 5,
          InferConnectivity = true
        TraceArgument traceArgument = new TraceArgument(circuitToTrace)
          ResultTypes = new List<ResultType> { ResultType.Circuit },
          ResultOptions = new ResultOptions() { IncludeGeometry = true }
        CircuitTracer circuitTracer = traceManager.GetTracer<CircuitTracer>();
        IReadOnlyList<Result> results = circuitTracer.Trace(traceArgument);
        // Iterate through the circuit trace results
          if (result is CircuitResult circuitResult)
            IReadOnlyList<CircuitPath> circuitPaths = circuitResult.CircuitPaths;
            foreach (CircuitPath circuitPath in circuitPaths)
              Circuit circuit = circuitPath.Circuit;
              TracePath path = circuitPath.Path;
              Geometry geometry = circuitPath.Geometry;
              IReadOnlyDictionary<int, TracePath> sectionPaths = circuitPath.SectionPaths;
              foreach (KeyValuePair<int, TracePath> sectionPath in sectionPaths)
                int sectionID = sectionPath.Key;
                TracePath sectionGeometry = sectionPath.Value;
                Console.WriteLine($"Section ID: {sectionID}, Section Geometry: {sectionGeometry.Geometry.ToJson()}");
          else
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.UtilityNetwork.Trace.PathConnectivity
    Requirements
    ArcGIS Pro version: 3.7 or higher.
