await QueuedTask.Run(() => { using (TraceManager traceManager = utilityNetwork.GetTraceManager()) using (NetworkSource deviceNetworkSource = telecomDomainNetwork.NetworkSources.First(f => f.Name.Contains("TelecomDevice"))) using (AssetGroup assetGroup = deviceNetworkSource.GetAssetGroup("Port")) using (AssetType assetType = assetGroup.GetAssetType("Port")) { Guid startGuid = new Guid("4BB4560A-34F3-4BBA-93D5-C5D6B26F2709"); Guid stopGuid = new Guid("32203C76-E484-473A-AEA5-B1AB92A0C198"); TelecomElement startElement = utilityNetwork.CreateElement(assetType, startGuid) as TelecomElement; TelecomElement stopElement = utilityNetwork.CreateElement(assetType, stopGuid) as TelecomElement; List<TelecomElement> startingLocations = new List<TelecomElement>() { startElement }; List<TelecomElement> stoppingLocations = new List<TelecomElement>() { stopElement }; TraceConfiguration traceConfiguration = new TraceConfiguration() { MaxHops = 100, NumPaths = 2, DomainNetwork = telecomDomainNetwork, ValidateConsistency = true }; TraceArgument traceArgument = new TraceArgument(startingLocations) { StoppingLocations = stoppingLocations, Configuration = traceConfiguration, ResultTypes = new List<ResultType>() { ResultType.Path }, ResultOptions = new ResultOptions { IncludeGeometry = true } }; PathTracer pathTracer = traceManager.GetTracer<PathTracer>(); IReadOnlyList<Result> results = pathTracer.Trace(traceArgument, ServiceSynchronizationType.Asynchronous); // Iterate through the path trace results foreach (Result result in results) { if (result is PathResult pathResult) { IReadOnlyList<TracePath> paths = pathResult.Paths; foreach (TracePath path in paths) { Element startLocation = path.StartLocation; Element stopLocation = path.StopLocation; Geometry pathGeometry = path.Geometry; IReadOnlyList<PathConnectivity> pathConnectivities = path.PathConnectivities; foreach (PathConnectivity pathConnectivity in pathConnectivities) { Console.WriteLine($"Edge: {pathConnectivity.Edge.GlobalID}, Junction: {pathConnectivity.Junction.GlobalID}"); } } } else { Console.WriteLine("Unexpected result type."); } } } });
System.Object
ArcGIS.Core.Data.UtilityNetwork.Trace.TracePath
ArcGIS.Core.Data.UtilityNetwork.Trace.OrderedTracePath
