ArcGIS.Desktop.Editing.COGO Namespace / CircularArcDefinition Class / CalculateRadialDirection Method
    Calculates the radial direction for the arc. The value is returned in North Azimuth decimal degrees.
    Syntax
    Public Function CalculateRadialDirection() As Double
    public double CalculateRadialDirection()
    Return Value
    The radial direction in North Azimuth decimal degrees.
    Exceptions
    ExceptionDescription
    The radial direction cannot be calculated.
    Remarks
    You should use CanCalculateRadialDirection prior to calculating the radial direction to determine if the arc definition has the appropriate values.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
