ArcGIS.Desktop.Editing.COGO Namespace / CircularArcDefinition Class / CalculateTangentDirection Method
    Calculates the tangent direction for the arc.The value is returned in North Azimuth decimal degrees.
    Syntax
    Public Function CalculateTangentDirection() As Double
    public double CalculateTangentDirection()
    Return Value
    The tangent direction in North Azimuth decimal degrees.
    Exceptions
    ExceptionDescription
    The tangent direction cannot be calculated.
    Remarks
    You should use CanCalculateTangentDirection prior to calculating the tangent direction to determine if the arc definition has the appropriate values.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
