var nAzDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("S7-46-51-E"); var cogoStraightLine = COGOLineBuilder.CreateCOGOStraightLine(nAzDirection, 61.45);
// Clockwise deflection angle 90 degrees, 50.00 var deflectionLine = COGOLineBuilder.CreateCOGOStraightLineByClockwiseDeflectionAngle(90.0, false, 50.00); //Clockwise backsight deflection angle 270 degrees, 50.00' var backSightDeflectionLine = COGOLineBuilder.CreateCOGOStraightLineByClockwiseDeflectionAngle(270.0, true, 50.00);
// define with a radius, arcLength and chord direction var circularArcDef = new CircularArcDefinition { Radius = -201.0, ArcLength = 45.29, ChordDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("N21-47-57W") }; var cogoCircArc = COGOLineBuilder.CreateCOGOCircularArc(circularArcDef); // define with a radius, chordLength and tangent direction var circularArcDef2 = new CircularArcDefinition { Radius = -201.0, ChordLength = 44.0, TangentDirection = 340.0 }; var cogoCircArc2 = COGOLineBuilder.CreateCOGOCircularArc(circularArcDef2); // define with a radius, central angle and radial direction var circularArcDef3 = new CircularArcDefinition { Radius = -201.0, CentralAngle = 44.0, RadialDirection = 340.0 }; var cogoCircArc3 = COGOLineBuilder.CreateCOGOCircularArc(circularArcDef3);
var tangentCircArcDef = new TangentCurveDefinition { Radius = 169.0, ArcLength = 52.40 }; var cogoTangentArc = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef); var tangentCircArcDef2 = new TangentCurveDefinition { Radius = -201.0, ChordLength = 23.24 }; var cogoTangentArc2 = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef2); var tangentCircArcDef3 = new TangentCurveDefinition { Radius = 169.0, CentralAngle = 44.0 }; var cogoTangentArc3 = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef3);
List<COGOLine> lstCOGOLines = new(); var direction = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("S7-46-51-E"); lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(nAzDirection, 61.45)); //1 lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(166.2625, 37.22));//2 lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(255.2833333, 71.4));//3 var circArcDef = new CircularArcDefinition { Radius = -201.0, ArcLength = 45.29, ChordDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("N21-47-57W") }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(circArcDef));//4 var tangentCurveDef = new TangentCurveDefinition { Radius = 169.0, ArcLength = 52.40 }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//5 tangentCurveDef = new TangentCurveDefinition { Radius = 13.0, ArcLength = 22.98 }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//6 tangentCurveDef = new TangentCurveDefinition { Radius = -281.0, ArcLength = 73.68 }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//7 var spatialReference = map?.SpatialReference; var travParcel = new Traverse(spatialReference); await travParcel.AddCoursesAsync(lstCOGOLines); if (travParcel.IsValid()) { ; //insert code to use the traverse }
System.Object
ArcGIS.Desktop.Editing.COGO.COGOLine
