Public Sub Adjust( _ ByVal adjustmentMethod As TraverseAdjustmentMethod _ )
public void Adjust( TraverseAdjustmentMethod adjustmentMethod )
Parameters
- adjustmentMethod
- The adjustment method to use.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.ArgumentException | Cannot adjust this traverse with the provided parameters. |
if (travParcel.IsValid()) { TraverseClosure travClosure = travParcel.GetClosure(); if (travClosure.MiscloseDistance < 0.1) { if (travParcel.CanAdjust(TraverseAdjustmentMethod.Compass)) { travParcel.Adjust(TraverseAdjustmentMethod.Compass); TraverseAdjustmentResults adjResults = travParcel.AdjustmentResults; var adjCoords = adjResults.AdjustedCoordinates; var adjustedCourses = adjResults.AdjustedCourses; var distanceResiduals = adjResults.DistanceResiduals; var directionResiduals = adjResults.DirectionalResiduals; } } }
