ArcGIS.Desktop.Editing.COGO Namespace / Traverse Class / GetClosure Method
Example
    GetClosure Method
    Gets the traverse closure. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetClosure() As TraverseClosure
    public TraverseClosure GetClosure()
    Return Value
    A TraverseClosure. Can return null if the traverse is not valid. See IsValid.
    Exceptions
    ExceptionDescription
    Example
    Traverse Closure
    if (travParcel.IsValid())
      string sReport = "";
      TraverseClosure travClosure = travParcel.GetClosure();
      var miscDistance = travClosure.MiscloseDistance;
      var miscDirection = travClosure.MiscloseDirection;
      var miscX = travClosure.MiscloseX;
      var miscY = travClosure.MiscloseY;
      var calcArea = travClosure.CalculatedArea;
      sReport = "Misclose distance: " + miscDistance.ToString("F2");
    Traverse Adjustment
      if (travClosure.MiscloseDistance < 0.1)
        if (travParcel.CanAdjust(TraverseAdjustmentMethod.Compass))
          travParcel.Adjust(TraverseAdjustmentMethod.Compass);
          TraverseAdjustmentResults adjResults = travParcel.AdjustmentResults;
          var adjCoords = adjResults.AdjustedCoordinates;
          var adjustedCourses = adjResults.AdjustedCourses;
          var distanceResiduals = adjResults.DistanceResiduals;
          var directionResiduals = adjResults.DirectionalResiduals;
    Requirements
    ArcGIS Pro version: 3.7 or higher.
