ArcGIS.Desktop.Editing.COGO Namespace / Traverse Class / Import Method
The path and name of the input file.
The spatial Reference for the traverse.
    Import Method (Traverse)
    Imports an ArcMap traverse file and creates a Traverse. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function Import( _
       ByVal inputFilePath As String, _
       ByVal sr As SpatialReference _
    ) As Traverse
    public static Traverse Import(
       string inputFilePath,
       SpatialReference sr
    Parameters
    inputFilePath
    sr
    Return Value
    Exceptions
    ExceptionDescription
    inputFilePath is not specified.
    inputFilePath does not exist.
    sr is null.
    There was an error importing the traverse.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
