ArcGIS.Desktop.Mapping Namespace / TerrainLayer Class / CanInterpolateShape Method
The geometry to be interpolated. It must be a point, multipoint, polyline or polygon.
Example
    CanInterpolateShape Method (TerrainLayer)
    Determines if values can be interpolated for the given geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CanInterpolateShape( _
       ByVal geometry As Geometry _
    ) As Boolean
    public bool CanInterpolateShape(
       Geometry geometry
    Parameters
    geometry
    Return Value
    True if the shape can be interpolated. False otherwise.
    Remarks
    It is important to call this method prior to InterpolateShape(Geometry,SurfaceInterpolationMethod) or InterpolateShape(Geometry,SurfaceInterpolationMethod,Double,Double) to ensure that a possible result can be found given the set of input parameters.
    This method also checks for a 3D Analyst license which is required to perform the analysis.
    Note that if this method returns true it does not preclude the InterpolateShape method from throwing an exception due to a calculation error and callers should code defensively and use appropriate exception handling.
    Example
    Interpolate Shape
      // Note: Needs QueuedTask to run
      // Note: Needs 3d Analyst license to run
        ArcGIS.Core.Geometry.Geometry output = null;
        // interpolate z values for a geometry
        if (terrainLayer.CanInterpolateShape(polyline))
          output = terrainLayer.InterpolateShape(polyline, SurfaceInterpolationMethod.NaturalNeighbor);
        if (output != null)
          // process the output
        // densify the shape before interpolating
        if (terrainLayer.CanInterpolateShape(polygon))
          output = terrainLayer.InterpolateShape(polygon, SurfaceInterpolationMethod.Linear, 0.01, 0);
        if (output != null)
    Requirements
    ArcGIS Pro version: 3.7 or higher.
