ArcGIS.Desktop.Mapping Namespace / TerrainLayer Class / InterpolateZ Method
The x coordinate.
The y coordinate.
The method of interpolation. The default method of interpolation for Terrains is SurfaceInterpolationMethod.Linear.
Example
    InterpolateZ Method (TerrainLayer)
    Interpolates the z coordinate of the specified xy location from the surface layer. This method requires a 3D Analyst license. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function InterpolateZ( _
       ByVal x As Double, _
       ByVal y As Double, _
       ByVal interpolationMethod As SurfaceInterpolationMethod _
    ) As Double
    Parameters
    x
    The x coordinate.
    y
    The y coordinate.
    interpolationMethod
    Return Value
    The surface elevation Z value.
    Exceptions
    ExceptionDescription
    x or y cannot be NaN.
    An exception occurred within the InterpolateShape calculation.
    A 3D Analyst license is required.
    Example
    Interpolate Z at an x,y location
      // Note: Needs QueuedTask to run
      // Note: Needs 3d Analyst license to run
        // interpolate values at the specified x,y location
        double z = terrainLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.NaturalNeighborZNearest);
        // or use a different interpolation method
        z = terrainLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.Linear);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
