ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / Circuit Class / IsSectioned Method
    IsSectioned Method
    Gets whether the circuit is sectioned. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsSectioned() As Boolean
    public bool IsSectioned()
    Return Value
    True if the circuit is sectioned; otherwise false.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
