ArcGIS.Core.Data Namespace / ArcGISServerConnectionFile Class
Members Example
    Represents the physical path to an ArcGIS Server connection file that ends with the .ags extension.
    Syntax
    public sealed class ArcGISServerConnectionFile : Connector
    Public NotInheritable Class ArcGISServerConnectionFile
       Inherits Connector
    Example
    Connect to the ArcGISServer using a connection file
      await QueuedTask.Run(() =>
        Uri uriPath = new Uri("path\\to\\the\\ArcGISServerConnectionFile.ags");
        ArcGISServerConnectionFile arcGISServerConnectionFile = new ArcGISServerConnectionFile(uriPath, "FeatureServiceName");
        using (Geodatabase geodatabase = new Geodatabase(arcGISServerConnectionFile))
          // Use the geodatabase.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.Connector
          ArcGIS.Core.Data.ArcGISServerConnectionFile
    Requirements
    ArcGIS Pro version: 3.8 or higher.
