ArcGIS.Desktop.Mapping Namespace / LasDatasetLayer Class / GetElevationRangeFromDatasetExtent Method
Example
    Gets the minimum and maximum elevation values from the extent of the data contained in the layer's dataset. The values are returned in meters. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public ValueTuple<double,double> GetElevationRangeFromDatasetExtent()
    Public Function GetElevationRangeFromDatasetExtent() As ValueTuple(Of Double,Double)
    Return Value
    The minimum and maximum elevation values.
    Exceptions
    ExceptionDescription
    Remarks
    If no extent can be found, then the values of System.Double.MinValue and System.Double.MaxValue are returned.
    Example
    Elevation Range Filter
      // get the state of the current elevation range filter
      var isEnabled = lasDatasetLayer.IsElevationRangeFilterEnabled;
      // turn off the filter
      lasDatasetLayer.SetElevationRangeFilterEnabled(false);  // or true to turn it on
      // get the current elevation range filter and access the values
      var elevRangeFilter = lasDatasetLayer.GetElevationRangeFilter();
      isEnabled = elevRangeFilter.IsEnabled;
      var minZ = elevRangeFilter.MinZ;
      var maxZ = elevRangeFilter.MaxZ;
      // get minimum and maximum Z values from the LAS Dataset
      (minZ, maxZ) = lasDatasetLayer.GetElevationRangeFromDatasetExtent();
      // set the elefvation range filter values
      //  note this doesn't change the enabled state of the elevation range filter
      lasDatasetLayer.SetElevationRangeFilter(1.2, 4.5);
      // or set the elevation range filter using a LasPointElevationRangeFilter
      elevRangeFilter = new LasPointElevationRangeFilter(true, 1.2, 4.5);
      lasDatasetLayer.SetElevationRangeFilter(elevRangeFilter);
    Requirements
    ArcGIS Pro version: 3.8 or higher.
