ArcGIS.Desktop.Mapping Namespace / LasDatasetLayer Class / SetElevationRangeFilterEnabled Method
The enabled state.
Example
    Sets the elevation range filter enabled state. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetElevationRangeFilterEnabled(
       bool enable
    Public Sub SetElevationRangeFilterEnabled( _
       ByVal enable As Boolean _
    Parameters
    enable
    The enabled state.
    Exceptions
    ExceptionDescription
    Example
    Elevation Range Filter
      // get the state of the current elevation range filter
      var isEnabled = lasDatasetLayer.IsElevationRangeFilterEnabled;
      // turn off the filter
      lasDatasetLayer.SetElevationRangeFilterEnabled(false);  // or true to turn it on
      // get the current elevation range filter and access the values
      var elevRangeFilter = lasDatasetLayer.GetElevationRangeFilter();
      isEnabled = elevRangeFilter.IsEnabled;
      var minZ = elevRangeFilter.MinZ;
      var maxZ = elevRangeFilter.MaxZ;
      // get minimum and maximum Z values from the LAS Dataset
      (minZ, maxZ) = lasDatasetLayer.GetElevationRangeFromDatasetExtent();
      // set the elefvation range filter values
      //  note this doesn't change the enabled state of the elevation range filter
      lasDatasetLayer.SetElevationRangeFilter(1.2, 4.5);
      // or set the elevation range filter using a LasPointElevationRangeFilter
      elevRangeFilter = new LasPointElevationRangeFilter(true, 1.2, 4.5);
      lasDatasetLayer.SetElevationRangeFilter(elevRangeFilter);
    Requirements
    ArcGIS Pro version: 3.8 or higher.
