ArcGIS.Core.Geometry Namespace / Geometry Class / IsEqual Method / IsEqual(Geometry,Double) Method
A geometry to test for equality while considering the tolerance.
The tolerance to be used when determining if the geometries are equal.
    Compares two geometries for equality while considering the given tolerance.
    Syntax
    public bool IsEqual(
       Geometry other,
       double tolerance
    Public Overloads Function IsEqual( _
       ByVal other As Geometry, _
       ByVal tolerance As Double _
    ) As Boolean
    Parameters
    other
    tolerance
    Return Value
    True if the two geometries are equal, false otherwise.
    Exceptions
    ExceptionDescription
    The input tolerance is < 0 or is NaN.
    Remarks
    The tolerance value is used to compare x, y, and other attributes. For example, if Abs(x1 - x2) <= tolerance, then x1 and x2 are considered to be equal. All other properties of the geometry have to be equal exactly (geometry type, point count, etc.). For topological equality, use relational operators instead of this function.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
