ArcGIS.Core.Geometry Namespace / Multipoint Class / IsEqual Method / IsEqual(Multipoint,Double) Method
A multipoint to test for equality.
The tolerance used to compare coordinates and attributes.
    Compares two Multipoint instances for equality using a tolerance.
    Syntax
    Public Overloads Function IsEqual( _
       ByVal multipoint As Multipoint, _
       ByVal tolerance As Double _
    ) As Boolean
    Parameters
    multipoint
    tolerance
    Return Value
    True if the two geometries are equal within tolerance; otherwise, false.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
