ArcGIS.Core.OCR Namespace / OCRBlock Class / Paragraphs Property
Example
    Paragraphs Property
    Gets the set of paragraphs within the block.
    Syntax
    public List<OCRParagraph> Paragraphs {get;}
    Public ReadOnly Property Paragraphs As List(Of OCRParagraph)
    Example
    Extract TSV output from a document
      string docFileName = "c:\\MyData\\MyDocument.bmp";
      var ocrOptions = new OCROptions(docFileName);
      ocrOptions.OutputType = OCROutputType.TSV;
      // set a specific page if necessary
      // (if not set, then all pages are scanned)
      // ocrOptions.Page = pageIdx;
      // set the resolution if necessary
      // ocrOptions.Resolution = 400;
      var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
      if (output is OCRTSVOutput ocr_tsvOutput)
        // process the tsv output
        foreach (var page in ocr_tsvOutput.Pages)
          foreach (var block in page.Blocks)
            foreach (var para in block.Paragraphs)
              foreach (var line in para.Lines)
                foreach (var word in line.Words)
                  var content = word.Content;
                  var confidence = word.Confidence;
                  // process content according to confidence
    Get text from TSVOutput (simple)
      string text = "";
      var flowDocument = new FlowDocument();
      foreach (var page in tsvOutput.Pages)
        List<Paragraph> pageParagraphs = new();
          foreach (var paragraph in block.Paragraphs)
            foreach (var line in paragraph.Lines)
              string lineWords = string.Join(" ", line.Words.Select(w => w.Content));
              pageParagraphs.Add(new Paragraph(new Span(new Run(lineWords))));
        flowDocument.Blocks.AddRange(pageParagraphs);
        flowDocument.Blocks.Add(new Paragraph(new Span(new Run(Environment.NewLine))));
      var startPointer = flowDocument?.ContentStart;
      var endPointer = flowDocument?.ContentEnd;
      if (startPointer != null && endPointer != null)
        text = new TextRange(startPointer, endPointer).Text;
    Requirements
    ArcGIS Pro version: 3.8 or higher.
