ArcGIS.Core.OCR Namespace / OCRManager Class / IsValidDocumentForOCR Method
The document file on disk.
Example
    Gets if the specified document is suitable for Optical Character Recognittion (OCR) in order to extract text.
    Syntax
    public bool IsValidDocumentForOCR(
       string documentFileName
    Public Function IsValidDocumentForOCR( _
       ByVal documentFileName As String _
    ) As Boolean
    Parameters
    documentFileName
    Return Value
    True if the file is supported for OCR; false otherwise.
    Remarks
    The following file extensions are supported - pdf, tif, tiff, jpg, jpeg, png and bmp.
    Example
    Determine if a document is valid for OCR
      string docFileName1 = "c:\\MyData\\MyDocument.pdf";
      string docFileName2 = "c:\\MyData\\MyDocument.bmp";
      string docFileName3 = "c:\\MyData\\MyDocument.txt";
      var isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName1);
      // isValid = true
      isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName2);
      // isValid = true
      isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName3);
      // isValid = false
    Requirements
    ArcGIS Pro version: 3.8 or higher.
