public static OCRManager Instance {get;}
Public Shared ReadOnly Property Instance As OCRManager
string docFileName1 = "c:\\MyData\\MyDocument.pdf";
string docFileName2 = "c:\\MyData\\MyDocument.bmp";
string docFileName3 = "c:\\MyData\\MyDocument.txt";
var isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName1);
// isValid = true
isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName2);
// isValid = true
isValid = OCRManager.Instance.IsValidDocumentForOCR(docFileName3);
// isValid = false
string docFileName = "c:\\MyData\\MyDocument.pdf";
var pageCount = OCRManager.Instance.GetDocumentPageCount(docFileName);
var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(docFileName);
// or extract from a specific page
//int pageIdx = 1;
//var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(deedFileName, pageIdx);
var text = "";
bool canceled = false;
using (CancelableProgressorSource cps = new CancelableProgressorSource("Reading document", "Canceled"))
canceled = await QueuedTask.Run<bool>(async () =>
try
text = await ArcGIS.Core.OCR.OCRManager.Instance.ExtractTextFromDocumentAsync(docFileName, cps.Progressor.CancellationToken);
catch (OperationCanceledException cex)
return true;
catch (Exception ex)
return false;
}, cps.Progressor);
if (canceled)
// to do - some cancel action
else
// to do - something with text
string docFileName = "c:\\MyData\\MyDocument.tiff";
var ocrOptions = new OCROptions(docFileName);
ocrOptions.OutputType = OCROutputType.Text;
// set a specific page if necessary
// (if not set, then all pages are scanned)
// ocrOptions.Page = pageIdx;
// set the resolution if necessary
// ocrOptions.Resolution = 400;
var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
var textOutput = output as OCRTextOutput;
var text = textOutput.Text;
string docFileName = "c:\\MyData\\MyDocument.jpg";
// set the language
// (de.traineddata should be installed at (arcgis_install_folder)\Resources\OCR)
// if file cannot be found an exception is thrown
ocrOptions.Model = "de";
try
catch (ArcGIS.Core.OCR.Exceptions.OCRException ex)
string docFileName = "c:\\MyData\\MyDocument.bmp";
ocrOptions.OutputType = OCROutputType.TSV;
if (output is OCRTSVOutput ocr_tsvOutput)
// process the tsv output
foreach (var page in ocr_tsvOutput.Pages)
foreach (var block in page.Blocks)
foreach (var para in block.Paragraphs)
foreach (var line in para.Lines)
foreach (var word in line.Words)
var content = word.Content;
var confidence = word.Confidence;
// process content according to confidence
