public List<OCRLine> Lines {get;}
Public ReadOnly Property Lines As List(Of OCRLine)
string docFileName = "c:\\MyData\\MyDocument.bmp";
var ocrOptions = new OCROptions(docFileName);
ocrOptions.OutputType = OCROutputType.TSV;
// set a specific page if necessary
// (if not set, then all pages are scanned)
// ocrOptions.Page = pageIdx;
// set the resolution if necessary
// ocrOptions.Resolution = 400;
var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
if (output is OCRTSVOutput ocr_tsvOutput)
// process the tsv output
foreach (var page in ocr_tsvOutput.Pages)
foreach (var block in page.Blocks)
foreach (var para in block.Paragraphs)
foreach (var line in para.Lines)
foreach (var word in line.Words)
var content = word.Content;
var confidence = word.Confidence;
// process content according to confidence
string text = "";
var flowDocument = new FlowDocument();
foreach (var page in tsvOutput.Pages)
List<Paragraph> pageParagraphs = new();
foreach (var paragraph in block.Paragraphs)
foreach (var line in paragraph.Lines)
string lineWords = string.Join(" ", line.Words.Select(w => w.Content));
pageParagraphs.Add(new Paragraph(new Span(new Run(lineWords))));
flowDocument.Blocks.AddRange(pageParagraphs);
flowDocument.Blocks.Add(new Paragraph(new Span(new Run(Environment.NewLine))));
var startPointer = flowDocument?.ContentStart;
var endPointer = flowDocument?.ContentEnd;
if (startPointer != null && endPointer != null)
text = new TextRange(startPointer, endPointer).Text;
