| Overload | Description |
| ExtractTraverseFromDeedText(String,SpatialReference) | Extracts a set of Traverse objects from raw deed text. This method must be called on the MCT. Use QueuedTask.Run. |
| ExtractTraverseFromDeedText(String,SpatialReference,CancellationToken) | Extracts a set of Traverse objects from raw deed text. This method must be called on the MCT. Use QueuedTask.Run. |
