ArcGIS.Desktop.Editing.COGO Namespace / TraverseFactory Class / Import Method
The path and name of the input file.
The spatial Reference for the traverse.
    Import Method (TraverseFactory)
    Imports an ArcMap traverse file and creates a Traverse. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    inputFilePath
    spatialReference
    Return Value
    Exceptions
    ExceptionDescription
    inputFilePath is not specified.
    inputFilePath does not exist.
    spatialReference is null.
    There was an error importing the traverse.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
