public Task<bool> IsValidDefinitionQuery( string sql )
Public Overloads Function IsValidDefinitionQuery( _ ByVal sql As String _ ) As Task(Of Boolean)
Parameters
- sql
- The SQL clause to check.
Return Value
True if valid.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
var us_parks = map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().First(l => l.Name == "USNationalParks");
var sql = "STATE_ABBR = 'CA'";
var isValid = await us_parks.IsValidDefinitionQuery(sql);
if (isValid)
await QueuedTask.Run(() =>
var def_query = new DefinitionQuery("CaliforniaParks", sql);
us_parks.InsertDefinitionQuery(def_query);
us_parks.SetDefinitionQuery("STATE_ABBR = 'CA'");
//Set it active
us_parks.SetActiveDefinitionQuery(def_query.Name);
//or....also - set it active when it is inserted
//us_parks.InsertDefinitionQuery(def_query, true);
if (isValid)
//inserts a new definition query and makes it active
//it will be assigned a unique name
us_parks.SetDefinitionQuery(sql);
