ArcGIS.Desktop.Mapping Namespace / BasicFeatureLayer Class / IsValidDefinitionQuery Method / IsValidDefinitionQuery(DefinitionQuery) Method
The definition query to check.
Example
    Determines if the specified definitionQuery is valid. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Task<bool> IsValidDefinitionQuery(
       DefinitionQuery definitionQuery
    Public Overloads Function IsValidDefinitionQuery( _
       ByVal definitionQuery As DefinitionQuery _
    ) As Task(Of Boolean)
    Parameters
    definitionQuery
    Return Value
    True if valid.
    Exceptions
    ExceptionDescription
    Remarks
    This method does not check whether records will be returned from the definitionQuery; just whether the query where clause has valid syntax for the layer and the spatial filter (if defined) is valid.
    Example
    Apply a Definition Query Filter to a Feature Layer
      var us_parks = map.GetLayersAsFlattenedList()
                        .OfType<FeatureLayer>().First(l => l.Name == "USNationalParks");
      var sql = "STATE_ABBR = 'CA'";
      var isValid = await us_parks.IsValidDefinitionQuery(sql);
      if (isValid)
        await QueuedTask.Run(() =>
          var def_query = new DefinitionQuery("CaliforniaParks", sql);
          us_parks.InsertDefinitionQuery(def_query);
          us_parks.SetDefinitionQuery("STATE_ABBR = 'CA'");
          //Set it active
          us_parks.SetActiveDefinitionQuery(def_query.Name);
          //or....also - set it active when it is inserted
          //us_parks.InsertDefinitionQuery(def_query, true);
    Apply a Definition Query Filter to a Feature Layer Option 2
      if (isValid)
        //inserts a new definition query and makes it active
        //it will be assigned a unique name
        us_parks.SetDefinitionQuery(sql);
    Apply a Definition Query Filter With a Filter Geometry to a Feature Layer
      var greatLakes = map.GetLayersAsFlattenedList()
            .OfType<FeatureLayer>().First(l => l.Name == "Great Lakes");
      var usa_states = map.GetLayersAsFlattenedList()
      .OfType<FeatureLayer>().First(l => l.Name == "US_States");
      //name must be unique
      var def_query = new DefinitionQuery("GreatLakes",
                            "NAME in ('Huron','Michigan','Erie')");
      //create a filter geometry - in this example we will use the outline geometry
      //of all visible features from a us states layer...the filter geometry will be
      //intersected with the layer feature geometry when added to the def query
      var filter_geom = await QueuedTask.Run(() =>
        usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Visible));
      //other options...
      //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.All);
      //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Selected);
      //Geometry must have a valid SR and be point, multi-point, line, or poly
        if (def_query.CanSetFilterGeometry(filter_geom))
          def_query.SetFilterGeometry(filter_geom);
      // test to ensure the definition query is valid
      var isValid = await greatLakes.IsValidDefinitionQuery(def_query);
      if (isValid)
          //Apply the def query
          greatLakes.InsertDefinitionQuery(def_query);
          //Set it active
          greatLakes.SetActiveDefinitionQuery(def_query.Name);
          //greatLakes.InsertDefinitionQuery(def_query, true);
    Requirements
    ArcGIS Pro version: 3.8 or higher.
