ArcGIS.Core.Data.DDL Namespace / CodedValueDomainDescription Class / CodedValuePairs Property
Example
    Returns the SortedList of coded value pairs.
    Syntax
    public SortedList<object,string> CodedValuePairs {get;}
    Public ReadOnly Property CodedValuePairs As SortedList(Of Object,String)
    Example
    Modifying domain
      Task ModifyDomainAsync(Geodatabase geodatabase, string codedValueDomainName = "Pipe") => QueuedTask.Run(() =>
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        CodedValueDomain codedValueDomain = geodatabase.GetDomains().First(f => f.GetName().Equals(codedValueDomainName)) as CodedValueDomain;
        CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription(codedValueDomain);
        // Update domain description
        codedValueDomainDescription.Description = "Water Pipe Domain";
        // Adding code/value pair
        codedValueDomainDescription.CodedValuePairs.Add("C", "Copper");
        schemaBuilder.Modify(codedValueDomainDescription);
        // To modify the orders of coded value domain
        // schemaBuilder.Modify(codedValueDomainDescription,SortBy.Name,SortOrder.Ascending);
        schemaBuilder.Build();
    Requirements
