ArcGIS.Core.Data.DDL Namespace / DomainDescription Class / Description Property
Example
    Description Property (DomainDescription)
    The description of the ArcGIS.Core.Data.Domain.
    Syntax
    Public Property Description As String
    public string Description {get; set;}
    Example
    Creating a Range domain
      // Must be called within QueuedTask.Run
      void CreateRangeDomainSnippet(Geodatabase geodatabase)
        // Create a range description with minimum value = 0 and maximum value = 1000
        RangeDomainDescription rangeDomainDescriptionMinMax = new RangeDomainDescription("RangeDomain_0_1000",
            FieldType.Integer, 0, 1000)
        { Description = "Domain value ranges from 0 to 1000" };
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Create  a range domain
        schemaBuilder.Create(rangeDomainDescriptionMinMax);
        schemaBuilder.Build();
    Requirements
