ArcGIS.Core.Data.DDL Namespace / FieldDescription Class / CreateGlobalIDField Method
Example
    Creates a field description for a Global ID ArcGIS.Core.Data.Field.
    Syntax
    Public Shared Function CreateGlobalIDField() As FieldDescription
    public static FieldDescription CreateGlobalIDField()
    Return Value
    A field description for a Global ID ArcGIS.Core.Data.Field.
    Example
    Creating a Table
      // Must be called within QueuedTask.Run
      void CreateTableSnippet(Geodatabase geodatabase, CodedValueDomain inspectionResultsDomain)
        // Create a PoleInspection table with the following fields
        // GlobalID
        // ObjectID
        // InspectionDate (date)
        // InspectionResults (pre-existing InspectionResults coded value domain)
        // InspectionNotes (string)
        // This helper routine creates a FieldDescription for a GlobalID field with default values
        FieldDescription globalIDFieldDescription = FieldDescription.CreateGlobalIDField();
        // This helper routine creates a FieldDescription for an ObjectID field with default values
        FieldDescription objectIDFieldDescription = FieldDescription.CreateObjectIDField();
        // Create a FieldDescription for the InspectionDate field
        FieldDescription inspectionDateFieldDescription = new FieldDescription("InspectionDate", FieldType.Date)
          AliasName = "Inspection Date"
        // This helper routine creates a FieldDescription for a Domain field (from a pre-existing domain)
        FieldDescription inspectionResultsFieldDescription = FieldDescription.CreateDomainField("InspectionResults",
          new CodedValueDomainDescription(inspectionResultsDomain));
        inspectionResultsFieldDescription.AliasName = "Inspection Results";
        // This helper routine creates a FieldDescription for a string field
        FieldDescription inspectionNotesFieldDescription =
          FieldDescription.CreateStringField("InspectionNotes", 512);
        inspectionNotesFieldDescription.AliasName = "Inspection Notes";
        // Assemble a list of all of our field descriptions
        List<FieldDescription> fieldDescriptions = new List<FieldDescription>()
            globalIDFieldDescription, objectIDFieldDescription, inspectionDateFieldDescription,
            inspectionResultsFieldDescription, inspectionNotesFieldDescription
        // Create a TableDescription object to describe the table to create
        TableDescription tableDescription = new TableDescription("PoleInspection", fieldDescriptions);
        // Create a SchemaBuilder object
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Add the creation of PoleInspection to our list of DDL tasks
        schemaBuilder.Create(tableDescription);
        // Execute the DDL
        bool success = schemaBuilder.Build();
        // Inspect error messages
        if (!success)
          IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
          //etc.
    Creating a feature class
      void CreateFeatureClassSnippet(Geodatabase geodatabase, FeatureClass existingFeatureClass,
        SpatialReference spatialReference)
        // Create a Cities feature class with the following fields
        // GlobalID
        // ObjectID
        // Name (string)
        // Population (integer)
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 255);
        // This helper routine creates a FieldDescription for an integer field
        FieldDescription populationFieldDescription = FieldDescription.CreateIntegerField("Population");
            { globalIDFieldDescription, objectIDFieldDescription, nameFieldDescription, populationFieldDescription };
        // Create a ShapeDescription object
        ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Point, spatialReference);
        // Alternatively, ShapeDescriptions can be created from another feature class.  In this case, the new feature class will inherit the same shape properties of the existing class
        ShapeDescription alternativeShapeDescription = new ShapeDescription(existingFeatureClass.GetDefinition());
        // Enable support for measure (M) value, if needed
        // shapeDescription.HasM = true;
        // Enable support for the vertical coordinate system (Z), if needed
        // shapeDescription.HasZ = true;
        // Create a FeatureClassDescription object to describe the feature class to create
        FeatureClassDescription featureClassDescription =
          new FeatureClassDescription("Cities", fieldDescriptions, shapeDescription);
        // Add the creation of the Cities feature class to our list of DDL tasks
        schemaBuilder.Create(featureClassDescription);
        // Execute the DDL
        if (!success)
          //etc.
    Adding fields to a FeatureClass
      void AddFieldsInFeatureClassSnippet(Geodatabase geodatabase)
        // Adding following fields to the 'Parcels' FeatureClass
        // Global ID
        // Parcel_ID
        // Tax_Code
        // Parcel_Address
        // The FeatureClass to add fields
        string featureClassName = "Parcels";
        FeatureClassDefinition originalFeatureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>(featureClassName);
        FeatureClassDescription originalFeatureClassDescription = new FeatureClassDescription(originalFeatureClassDefinition);
        // The four new fields to add on the 'Parcels' FeatureClass
        FieldDescription globalIdField = FieldDescription.CreateGlobalIDField();
        FieldDescription parcelIdDescription = new FieldDescription("Parcel_ID", FieldType.GUID);
        FieldDescription taxCodeDescription = FieldDescription.CreateIntegerField("Tax_Code");
        FieldDescription addressDescription = FieldDescription.CreateStringField("Parcel_Address", 150);
        List<FieldDescription> fieldsToAdd = new List<FieldDescription>
            globalIdField, parcelIdDescription,
            taxCodeDescription, addressDescription
        // Add new fields on the new FieldDescription list
        List<FieldDescription> modifiedFieldDescriptions = new List<FieldDescription>(originalFeatureClassDescription.FieldDescriptions);
        modifiedFieldDescriptions.AddRange(fieldsToAdd);
        // The new FeatureClassDescription with additional fields
        FeatureClassDescription modifiedFeatureClassDescription = new FeatureClassDescription(originalFeatureClassDescription.Name,
          modifiedFieldDescriptions, originalFeatureClassDescription.ShapeDescription);
        // Update the 'Parcels' FeatureClass with newly added fields
        schemaBuilder.Modify(modifiedFeatureClassDescription);
        bool modifyStatus = schemaBuilder.Build();
        if (!modifyStatus)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
    Creating an annotation feature class
      void CreateStandAloneAnnotationFeatureClass(
        Geodatabase geodatabase, SpatialReference spatialReference)
        // Creating a Cities annotation feature class
        // with following user defined fields
        // Name
        // GlobalID
        // Annotation feature class name
        string annotationFeatureClassName = "CitiesAnnotation";
        // Create user defined attribute fields for annotation feature class
        // Create a list of all field descriptions
            { globalIDFieldDescription, nameFieldDescription };
        ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Polygon, spatialReference);
        // Create general placement properties for Maplex engine
        CIMMaplexGeneralPlacementProperties generalPlacementProperties =
          new CIMMaplexGeneralPlacementProperties
            AllowBorderOverlap = true,
            PlacementQuality = MaplexQualityType.High,
            DrawUnplacedLabels = true,
            InvertedLabelTolerance = 1.0,
            RotateLabelWithDisplay = true,
            UnplacedLabelColor = new CIMRGBColor
              R = 0,
              G = 255,
              B = 0,
              Alpha = 0.5f // Green
        // Create general placement properties for Standard engine
        //CIMStandardGeneralPlacementProperties generalPlacementProperties =
        //  new CIMStandardGeneralPlacementProperties
        //    DrawUnplacedLabels = true,
        //    InvertedLabelTolerance = 3.0,
        //    RotateLabelWithDisplay = true,
        //    UnplacedLabelColor = new CIMRGBColor
        //      R = 255, G = 0, B = 0, Alpha = 0.5f // Red
        // Create annotation  label classes
        // Green label
        CIMLabelClass greenLabelClass = new CIMLabelClass
          Name = "Green",
          ExpressionTitle = "Expression-Green",
          ExpressionEngine = LabelExpressionEngine.Arcade,
          Expression = "$feature.OBJECTID",
          ID = 1,
          Priority = 0,
          Visibility = true,
          TextSymbol = new CIMSymbolReference
            Symbol = new CIMTextSymbol()
              Angle = 45,
              FontType = FontType.Type1,
              FontFamilyName = "Tahoma",
              FontEffects = FontEffects.Normal,
              HaloSize = 2.0,
              Symbol = new CIMPolygonSymbol
                SymbolLayers = new CIMSymbolLayer[]
                    new CIMSolidFill
                      Color = CIMColor.CreateRGBColor(0, 255, 0)
                UseRealWorldSymbolSizes = true
            MaxScale = 0,
            MinScale = 0,
            SymbolName = "TextSymbol-Green"
          StandardLabelPlacementProperties = new CIMStandardLabelPlacementProperties
            AllowOverlappingLabels = true,
            LineOffset = 1.0
          MaplexLabelPlacementProperties = new CIMMaplexLabelPlacementProperties
            AlignLabelToLineDirection = true,
            AvoidPolygonHoles = true
        // Blue label
        CIMLabelClass blueLabelClass = new CIMLabelClass
          Name = "Blue",
          ExpressionTitle = "Expression-Blue",
          ID = 2,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              FontFamilyName = "Consolas",
              HaloSize = 2.0,
                    new CIMSolidFill
                      Color = CIMColor.CreateRGBColor(0, 0, 255)
            MaxScale = 0,
            MinScale = 0,
            SymbolName = "TextSymbol-Blue"
            LineOffset = 1.0
        // Create a list of labels
        List<CIMLabelClass> labelClasses = new List<CIMLabelClass> { greenLabelClass, blueLabelClass };
        // Create an annotation feature class description object to describe the feature class to create
        AnnotationFeatureClassDescription annotationFeatureClassDescription =
          new AnnotationFeatureClassDescription(annotationFeatureClassName, fieldDescriptions, shapeDescription,
            generalPlacementProperties, labelClasses)
            IsAutoCreate = true,
            IsSymbolIDRequired = false,
            IsUpdatedOnShapeChange = true
        // Add the creation of the Cities annotation feature class to the list of DDL tasks
        schemaBuilder.Create(annotationFeatureClassDescription);
        // Execute the DDL
        if (!success)
          //etc.
    Creating a feature-linked annotation feature class
      void CreateFeatureLinkedAnnotationFeatureClass(Geodatabase geodatabase,
        // Creating a feature-linked annotation feature class between water pipe and valve in water distribution network
        // PipeName
        // GlobalID
        string annotationFeatureClassName = "WaterPipeAnnotation";
        FieldDescription pipeGlobalID = FieldDescription.CreateGlobalIDField();
            { pipeGlobalID, nameFieldDescription };
        CIMMaplexGeneralPlacementProperties generalPlacementProperties = new CIMMaplexGeneralPlacementProperties
            R = 255,
            G = 0,
            B = 0,
            Alpha = 0.5f
        // Green label
          Name = "Green",
          ID = 1,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              HaloSize = 2.0,
                    new CIMSolidFill
            MaxScale = 0,
            MinScale = 0,
            LineOffset = 1.0
        // Blue label
          Name = "Blue",
          ID = 2,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              HaloSize = 2.0,
                    new CIMSolidFill
            MaxScale = 0,
            MinScale = 0,
            LineOffset = 1.0
        // Create linked feature description
        // Linked feature class name
        string linkedFeatureClassName = "WaterPipe";
        // Create fields for water pipe
        FieldDescription waterPipeGlobalID = FieldDescription.CreateGlobalIDField();
        FieldDescription pipeName = FieldDescription.CreateStringField("PipeName", 255);
        // Create a list of water pipe field descriptions
        List<FieldDescription> pipeFieldDescriptions = new List<FieldDescription> { waterPipeGlobalID, pipeName };
        // Create a linked feature class description
        FeatureClassDescription linkedFeatureClassDescription = new FeatureClassDescription(linkedFeatureClassName,
          pipeFieldDescriptions,
          new ShapeDescription(GeometryType.Polyline, spatialReference));
        // Add the creation of the linked feature class to the list of DDL tasks
        FeatureClassToken linkedFeatureClassToken = schemaBuilder.Create(linkedFeatureClassDescription);
            generalPlacementProperties, labelClasses, new FeatureClassDescription(linkedFeatureClassToken))
        // Add the creation of the annotation feature class to the list of DDL tasks
        // Execute the DDL
        if (!success)
          //etc.
    Requirements
