public static FieldDescription CreateObjectIDField()
Public Shared Function CreateObjectIDField() As FieldDescription
Return Value
A field description for an Object ID ArcGIS.Core.Data.Field.
Task CreateTableSnippetAsync(Geodatabase geodatabase, CodedValueDomain inspectionResultsDomain) => QueuedTask.Run(() =>
// Create a PoleInspection table with the following fields
// GlobalID
// ObjectID
// InspectionDate (date)
// InspectionResults (pre-existing InspectionResults coded value domain)
// InspectionNotes (string)
// This helper routine creates a FieldDescription for a GlobalID field with default values
FieldDescription globalIDFieldDescription = FieldDescription.CreateGlobalIDField();
// This helper routine creates a FieldDescription for an ObjectID field with default values
FieldDescription objectIDFieldDescription = FieldDescription.CreateObjectIDField();
// Create a FieldDescription for the InspectionDate field
FieldDescription inspectionDateFieldDescription = new FieldDescription("InspectionDate", FieldType.Date)
AliasName = "Inspection Date"
// This helper routine creates a FieldDescription for a Domain field (from a pre-existing domain)
FieldDescription inspectionResultsFieldDescription = FieldDescription.CreateDomainField("InspectionResults",
new CodedValueDomainDescription(inspectionResultsDomain));
inspectionResultsFieldDescription.AliasName = "Inspection Results";
// This helper routine creates a FieldDescription for a string field
FieldDescription inspectionNotesFieldDescription =
FieldDescription.CreateStringField("InspectionNotes", 512);
inspectionNotesFieldDescription.AliasName = "Inspection Notes";
// Assemble a list of all of our field descriptions
List<FieldDescription> fieldDescriptions = new List<FieldDescription>()
globalIDFieldDescription, objectIDFieldDescription, inspectionDateFieldDescription,
inspectionResultsFieldDescription, inspectionNotesFieldDescription
// Create a TableDescription object to describe the table to create
TableDescription tableDescription = new TableDescription("PoleInspection", fieldDescriptions);
// Create a SchemaBuilder object
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Add the creation of PoleInspection to our list of DDL tasks
schemaBuilder.Create(tableDescription);
// Execute the DDL
bool success = schemaBuilder.Build();
// Inspect error messages
if (!success)
IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
//etc.
Task CreateFeatureClassSnippetAsync(Geodatabase geodatabase, FeatureClass existingFeatureClass,
SpatialReference spatialReference) => QueuedTask.Run(() =>
// Create a Cities feature class with the following fields
// GlobalID
// ObjectID
// Name (string)
// Population (integer)
FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 255);
// This helper routine creates a FieldDescription for an integer field
FieldDescription populationFieldDescription = FieldDescription.CreateIntegerField("Population");
{ globalIDFieldDescription, objectIDFieldDescription, nameFieldDescription, populationFieldDescription };
// Create a ShapeDescription object
ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Point, spatialReference);
// Alternatively, ShapeDescriptions can be created from another feature class. In this case, the new feature class will inherit the same shape properties of the existing class
ShapeDescription alternativeShapeDescription = new ShapeDescription(existingFeatureClass.GetDefinition());
// Enable support for measure (M) value, if needed
// shapeDescription.HasM = true;
// Enable support for the vertical coordinate system (Z), if needed
// shapeDescription.HasZ = true;
// Create a FeatureClassDescription object to describe the feature class to create
FeatureClassDescription featureClassDescription =
new FeatureClassDescription("Cities", fieldDescriptions, shapeDescription);
// Add the creation of the Cities feature class to our list of DDL tasks
schemaBuilder.Create(featureClassDescription);
// Execute the DDL
if (!success)
//etc.
