Parameters
- name
- The name of the description.
- fieldType
- The ArcGIS.Core.Data.FieldType of the description.
- minValue
- The minimum value for the range.
- maxValue
- The maximum value for the range.
| Exception | Description |
| System.ArgumentException | name is invalid. -or- fieldType is invalid. The only valid types are ArcGIS.Core.Data.FieldType.SmallInteger, ArcGIS.Core.Data.FieldType.Integer, ArcGIS.Core.Data.FieldType.Single, ArcGIS.Core.Data.FieldType.Double, and ArcGIS.Core.Data.FieldType.Date. -or- The type of minValue and/or maxValue is invalid. The expected type for ArcGIS.Core.Data.FieldType.Date is System.DateTime. The expected type for ArcGIS.Core.Data.FieldType.SmallInteger and ArcGIS.Core.Data.FieldType.Integer is an integer. The expected type for ArcGIS.Core.Data.FieldType.Single and ArcGIS.Core.Data.FieldType.Double is a float. -or- |
| System.ArgumentNullException | minValue and/or maxValue are null. |
| System.ArgumentOutOfRangeException | The System.DateTime object is representing a year earlier than the year 100 AD. |
