ArcGIS.Desktop.Layouts Namespace / Element Class / SetCustomProperties Method
The collection of custom properties
    SetCustomProperties Method (Element)
    Sets multiple CustomProperty values for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetCustomProperties( _
       ByVal customProperties As IEnumerable(Of CIMStringMap) _
    public void SetCustomProperties(
       IEnumerable<CIMStringMap> customProperties
    Parameters
    customProperties
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    This method was created so developers have a way to uniquely assign a value or multiple values to an element that can not be changed in the UI and therefore provides a predictable way to find an element. You can overwrite values simply be reentering the same key with a different value in the input collection. There are no methods to remove keys.
    Requirements
