ArcGIS.Core.Data Namespace / SelectionOption Enumeration
Example Example
    Specifies the content of the selection.
    Syntax
    Members
    MemberDescription
    Empty An empty selection is created.
    Normal The selection is created containing all rows returned by the query.
    OnlyOne The selection is created containing the first row returned by the query.
    Example
    Selecting Rows from a Table
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
          QueryFilter anotherQueryFilter = new QueryFilter { WhereClause = "FLOOR = 1 AND WING = 'E'" };
          // For Selecting all matching entries.
          using (Selection anotherSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Normal))
          // This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the criteria is selected.
          using (Selection onlyOneSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
          // This can be used to obtain a empty selection which can be used as a container to combine results from different selections.
          using (Selection emptySelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Empty))
          // If you want to select all the records in a table.
          using (Selection allRecordSelection = enterpriseTable.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
    Selecting Features from a FeatureClass
        using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
          List<Coordinate2D> newCoordinates = new List<Coordinate2D>
            new Coordinate2D(1021570, 1880583),
            new Coordinate2D(1028730, 1880994),
            new Coordinate2D(1029718, 1875644),
            new Coordinate2D(1021405, 1875397)
          SpatialQueryFilter spatialFilter = new SpatialQueryFilter
            WhereClause = "FCODE = 'Park'",
            FilterGeometry = new PolygonBuilderEx(newCoordinates).ToGeometry(),
            SpatialRelationship = SpatialRelationship.Crosses
          using (Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal))
          // criteria is selected.
          using (Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
          // This can be used to obtain an empty selction which can be used as a container to combine results from different selections.
          using (Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty))
          using (Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.SelectionOption
    Requirements
