ArcGIS.Core.Data Namespace / Attachment Class
Members Example
    Attachment Class
    Represents a document associated with a row.
    Syntax
    Public NotInheritable Class Attachment
       Inherits ArcGIS.Core.CoreObjectsBase
       Implements System.IDisposable
    public sealed class Attachment : ArcGIS.Core.CoreObjectsBase, System.IDisposable
    Example
    Adding Attachments
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (FeatureClass parkFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.Park"))
          QueryFilter filter = new QueryFilter { WhereClause = "NUMPARKING > 0" };
          using (RowCursor parkingCursor = parkFeatureClass.Search(filter, false))
            while (parkingCursor.MoveNext())
              using (MemoryStream stream = CreateMemoryStreamFromContentsOf("Sample.xml"))
                Attachment attachment = new Attachment("Sample.xml", "text/xml", stream);
                using (Row row = parkingCursor.Current)
                  long attachmentId = row.AddAttachment(attachment);
      // Helper method to read a file into a memory stream
      MemoryStream CreateMemoryStreamFromContentsOf(String fileNameWithPath)
        MemoryStream memoryStream = new MemoryStream();
        using (FileStream file = new FileStream(fileNameWithPath, FileMode.Open, FileAccess.Read))
          byte[] bytes = new byte[file.Length];
          file.Read(bytes, 0, (int)file.Length);
          memoryStream.Write(bytes, 0, (int)file.Length);
        return memoryStream;
    Updating Attachments
        using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
          QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
          using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
            while (landUseCursor.MoveNext())
              using (Feature rezoningUseCase = (Feature)landUseCursor.Current)
                IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
                IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
                foreach (Attachment attachmentToUpdate in filteredAttachments)
                  attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
                  rezoningUseCase.UpdateAttachment(attachmentToUpdate);
    Inheritance Hierarchy
    System.Object
          ArcGIS.Core.Data.Attachment
    Requirements
