Parameters
- fieldName
- The name of the field to be found.
Return Value
A positive integer value if the field is found indicating the index position of the field. If a field is not found with a name matching the fieldName, -1 is returned.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
