ArcGIS.Core.Data Namespace / AttributedRelationship Class / GetObjectID Method
    GetObjectID Method (AttributedRelationship)
    Gets the object ID of the row. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public long GetObjectID()
    Public Function GetObjectID() As Long
    Return Value
    The object ID of the row.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
