await QueuedTask.Run(() =>
// Opening a Non-Versioned SQL Server instance.
DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
AuthenticationMode = AuthenticationMode.DBMS,
// Where testMachine is the machine where the instance is running and testInstance is the name of the SqlServer instance.
Instance = @"testMachine\testInstance",
// Provided that a database called LocalGovernment has been created on the testInstance and geodatabase has been enabled on the database.
Database = "LocalGovernment",
// Provided that a login called gdb has been created and corresponding schema has been created with the required permissions.
User = "gdb",
Password = "password",
Version = "dbo.DEFAULT"
using (Geodatabase geodatabase = new Geodatabase(connectionProperties))
// Use the geodatabase
DatabaseConnectionProperties databaseConnectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
Instance = "instance",
Database = "database",
User = "user",
using (Database database = new Database(databaseConnectionProperties))
QueryDescription queryDescription = database.GetQueryDescription("CUSTOMERS");
using (Table table = database.OpenTable(queryDescription))
//use table
