ArcGIS.Core.Data Namespace / Definition Class / GetName Method
Example
    GetName Method (Definition)
    Gets the name of the definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetName() As String
    public string GetName()
    Return Value
    The name of the definition.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Obtaining List of Definitions from Geodatabase
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
          IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
          IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
          IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
          bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
          IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
          IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
    Access the bands in a raster dataset
      var count = rasterDataset.GetBandCount();
      RasterBand rasterBandByName = rasterDataset.GetBandByName(sBandName);
      var index = rasterDataset.GetBandIndex(sBandName);
      // Get a RasterBand from the raster dataset
      RasterBand rasterBand = rasterDataset.GetBand(0);
      // Get the RasterBandDefinition from the raster band.
      RasterBandDefinition rasterBandDefinition = rasterBand.GetDefinition();
      // Get the name of the raster band from the raster band.
      string bandName = rasterBandDefinition.GetName();
    Requirements
