ArcGIS.Core.Data Namespace / FeatureClassDefinition Class / GetLengthField Method
    Gets the name of the field containing the length of the shape. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetLengthField() As String
    public string GetLengthField()
    Return Value
    The name of the field containing the length of the shape.
    Exceptions
    ExceptionDescription
    The definition does not support this operation (e.g., the feature class is a shapefile).
    A geodatabase-related exception has occurred.
    Requirements
