ArcGIS.Core.Data Namespace / FeatureClassDefinition Class / GetShapeField Method
Example
    GetShapeField Method (FeatureClassDefinition)
    Gets the name of the field where the shape (geometry) is stored. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetShapeField() As String
    public string GetShapeField()
    Return Value
    The name of the field where the shape (geometry) is stored.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Obtaining Definitions from a Feature Service by Layer ID
      //Url examples for (federated) feature services
      //(by "ref" online):
      var url =
          @"https://sampleserver6.arcgisonline.com/arcgis/rest/services/SF311/FeatureServer";
      //(federated by ref on portal)
      //https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer");
      //(federated by value - Hosted - on portal)
      //https://portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer");
      await QueuedTask.Run(() =>
        var uri = new Uri(url, UriKind.Absolute);
        using (var fs_db = new ArcGIS.Core.Data.Geodatabase(new ServiceConnectionProperties(uri)))
          //Assuming that id 0 is a FeatureClass for the given service
          FeatureClassDefinition featureClassDefinition =
              fs_db.GetDefinition<FeatureClassDefinition>("0");
          string shapeField = featureClassDefinition.GetShapeField();
          IReadOnlyList<Field> fields = featureClassDefinition.GetFields();
          //Assuming that id 1 is a Table for the given service
          TableDefinition tableDefinition =
                fs_db.GetDefinition<TableDefinition>("1");
          string objectIDField = tableDefinition.GetObjectIDField();
    Requirements
