Public Function GetSpatialReference() As SpatialReference
public SpatialReference GetSpatialReference()
Return Value
The ArcGIS.Core.Geometry.SpatialReference for the FeatureClass.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// Note: call within QueuedTask.Run() { if (!featSceneLayer.HasAssociatedFeatureService) return;//no search or select //Select all features within the current map view var sz = MapView.Active.GetViewSize(); var map_pt1 = MapView.Active.ClientToMap(new System.Windows.Point(0, sz.Height)); var map_pt2 = MapView.Active.ClientToMap(new System.Windows.Point(sz.Width, 0)); //Convert to an envelope var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, MapView.Active.Map.SpatialReference); //Project if needed to the layer spatial ref SpatialReference sr = null; using (var fc = featSceneLayer.GetFeatureClass()) using (var fdef = fc.GetDefinition()) sr = fdef.GetSpatialReference(); var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope; //Set up a query filter var sf = new SpatialQueryFilter() { FilterGeometry = env, SpatialRelationship = SpatialRelationship.Intersects, SubFields = "*" }; //Select against the feature service var select = featSceneLayer.Select(sf); if (select.GetCount() > 0) { //enumerate over the selected features using (var rc = select.Search()) { while (rc.MoveNext()) { using (var feature = rc.Current as Feature) { oid = feature.GetObjectID(); //etc. } } } } MapView.Active.Map.ClearSelection(); }
