ArcGIS.Core.Data Namespace / FeatureDatasetDefinition Class / GetExtent Method
    GetExtent Method (FeatureDatasetDefinition)
    Gets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that is contained by the FeatureDataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Envelope GetExtent()
    Public Function GetExtent() As Envelope
    Return Value
    An ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that is contained by the FeatureDataset.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
